I need to convert an SRT file to SSA for use with Virtualdubmod but when I use the SRT to SSA converter I just get a "Input File Error, Subtitle #1" followed by a "Job Finished" message. The resulting SSA file is only 1k. Any ideas or suggestions as to another converter program ?
EDIT: I found one in the shape of "Script Converter", works a treat.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
are you sure your srt file is ok? Try using another srt file you know that works - or download one off the web and check it.
The srt file is fine. I used another converter called Script Converter and it converted to SSA straight away.Originally Posted by farcusnz
Don't really care as long as it works. Now to get on with that La Haine Rip so I can actually read the bloody subtitles.
Convert sub to srt/smi/psb/ssa/ass/son with Subresync
By FireWalker in forum User guidesReplies: 14Last Post: 12th Jul 2019, 02:03 -
Tool to convert SRT/SSA to Sony DVD Architect subtitles ?
By miguelos_net in forum SubtitleReplies: 4Last Post: 4th Dec 2011, 21:48 -
Converting vietnamese srt to ssa
By Nokia 2680 in forum SubtitleReplies: 20Last Post: 9th Dec 2008, 08:59 -
Batch SSA to SRT Converter
By m93 in forum SubtitleReplies: 1Last Post: 21st Jul 2008, 17:58 -
How to convert .SSA to .SRT for with a Mac
By VidHunter in forum MacReplies: 8Last Post: 27th Apr 2008, 15:34
