Hello folks,
Those pics are taken from a VHS capture. The tape is very precious to me, so I would like to have a digital copy. About the VHS tape: PAL-M, recorded in 1988 using the EP/SLP speed.
How can I filter this the best way?
Thank you!
(Interlaced)
It looks like this video has lots of problems. If that's all you have to work with, I would try Virtualdubmod. It's available in the 'Tools' section. I am assuming it is a Mpeg file. Anyway, try all the filters. There are quite a few available for Virtualdub (check the website). You can probably clean it up a bit, but don't expect miracles. Usually the best you can do is stabalize the video, and correct some of the colors, contrast and brightness.
Using VirtualDub's "capture filter" proc amp
By sanlyn in forum Capturing and VCRReplies: 3Last Post: 31st Jan 2012, 07:13 -
I want to know How do I add this filter
By Back in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2011, 09:04 -
best DVD recorder filter & ATI AIW filter
By VCRcomp in forum RestorationReplies: 1Last Post: 27th Jan 2011, 17:27 -
Need Avisynth filter
By fubuki81 in forum RestorationReplies: 5Last Post: 30th Sep 2008, 13:04 -
VirtualDub Filter During Capture?
By CosmicOutburst in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2007, 18:48
