When I use TMPGEnc under windows XP it locks up everytime I go to use the merge and cut option. In general the Win XP is awesome but I have noticed that it slows down to a crwal sometimes for some reason. Does anyone have the same problems? If so, how did you solve?
Results 1 to 1 of 1
Bad xvid video quality in windows 7!
By TempSiZ in forum Software PlayingReplies: 22Last Post: 7th Jul 2013, 14:50 -
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 07:00 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
DVDRecorder combo: bad qual recording: Defect or unit limitation: edited
By redraif in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2007, 20:50 -
installing windows me has a bad effect on my hard disk?
By ieh4f in forum ComputerReplies: 2Last Post: 10th Jul 2007, 12:02
