First post! I am eager to contribute and ask a few questions. I have been searching and reading for over a week, this is a GREAT resource!
May I ask you a simple question? I can capture from my camera in either mpeg2 format using PowerVCR III or I can capture a raw DV-avi. My goal is to put my home moives on DVD-Video. For the best quality, am I better off capturing in raw avi and converting with TMPGEnc or straight mpeg2. I burned my straight mpeg2 captures and the quality was OK (not great) on my TV. I have a JVC MiniDV Camera, Plextor 8X dual format burner and using TMPGEnc Plus, TMPGEnc DVD Author and Nero.
Thanks,
LJ
Results 1 to 12 of 12
Originally Posted by LarryJoe
Thanks bugster, this is what I suspected, but I did not realize that the DV-avi capture was a data transfer. I am a newbie at this.
Funny thing before I bought and hookded up my cam, I anticipated that when you connect a DV-Cams to PC via Firewire that it would show up as a drive letter and there would be an mpeg2 file sitting there to cut/copy and paste. Guess we are not there yet. Again, I'm learning! -
Your system may be fast enough to capture MPEG2 straight from the camera. It's easy to test. Just do a few clips each way, burn them on an RW with a test menu selection and compare. If you can go straight to MPEG2 you'll save yourself a bunch of time......
Good luck -
Will do Bottle-necked. I am running a P4 2.0 at 3.0. 512MB of PC800 Rambus overclocked as well. My capture card is an Avermedia PC Studio. I hear you on the time thing, it took about 20 minutes to encode/transcode my 45 minute dv-avi. Going straight to mpeg2 would save a lot of time.
Thanks!
LJ -
Definately transfer DV via firewire, then convert to mpeg2 with tmpgenc.
Thanks. Just re-read my last post and realized that the AverMedia card has nothing to do with capturing DV in either DV-avi or mpeg. Don't what I was thinking, it was early!
LJ -
Capture in DV-AVI because:
- Much easier to edit afterwards than MPEG2 (because of the GOP structure - IBP frames)
- Can perform 2-pass MPEG2 encoding for better quality after the files are on your hard drive. -
Originally Posted by bottle-necked
How do you cool it, 50% spped increase, thats some going.
Air cooled. I have an after market fan on the CPU, but I don't really think this makes a huge diff between the Intel retail fan. My chip was the latest stepping when I bought it a year ago. As I write, I am encoding an AVI to mpeg2 and the chip is at 42C.
Got lucky I guess.
Video capture straight to temporary storage?
By travail in forum Capturing and VCRReplies: 6Last Post: 2nd Jul 2011, 19:20 -
Capture video straight to DVD (for MAC)
By eutapio in forum MacReplies: 11Last Post: 29th Apr 2011, 15:19 -
Batch convert DV-AVI to MPEG2
By w@ntonsoup in forum Video ConversionReplies: 3Last Post: 27th Sep 2009, 15:08 -
Recording straight to MPEG2 PAL Video using a Hauppauge HVR-1800
By 3_2_DVD in forum Capturing and VCRReplies: 7Last Post: 22nd Sep 2009, 11:28 -
PCI and USB capture devices to AVOID? Go straight to WME...
By tedbragg in forum Capturing and VCRReplies: 0Last Post: 29th Feb 2008, 10:02
