    Jul 2003
    Nr Manchester, UK
    I have a kvcd that apparently will fit onto 1 cdr. I believe I need to convert to bin/cue file(s) and burn through toast, firstly I have tried this and I get a blank screen and no picture. Also with another SVCD image I have turned into bin/cue files and burnt in toast, toast states the image will fit onto 2 cdrom's but it only burns one of them and not giving the option of burning the second cd.
    Satman68
    Dec 2002
    It's VCD not SVCD, it makes a difference in the CDR file structure. You also ahve to burn it as non-complient (which it's not).
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
    Jul 2003
    Nr Manchester, UK
    Sorry I should have stated them as follows:-
    1. I have a kvcd image (mpeg) that I want onto cd, I can I do this?
    2. I have a SVCD image of a totally different file not related to KVCD that I want onto cd. I have turned it into a bin/cue file which burns ok, but I only get 3/4 of the movie on the cd, toast states it will be 2 cdroms so why doesn't it tell me to insert the second cd for burning?
