  1. Hi,
    I am trying to join 15 VOB files, each having aprox 3 minutes of video, into 1 big VOB file.
    But when i join them, all programs turn them into several VOB files each being aprox 1 gb large.
    There's no way to make 1 VOB file, 3-4 gb large?
    If so, which program should i use??
    I need them all in 1 file because i am trying to use DVDlab to author a dvd, and if i add these 1 gb VOB files DVDlab will make 1 seperate chapter selection screen for each file.
    Please help!
  2. Member FT Shark's Avatar
    Feb 2002
    Land Down Under
    There is no point to what you are trying to do. The DVD standard is 1gb max per VOB, other wise it can't be read by a DVD player. If you want one be file I suggest you create MPEG-2 files out of them and join those. No re-encoding will be necessary just a little de-multiplexing, re-multiplexing, and joining. Should only take a few minutes per file.
  3. Use VOBMerge for what you are trying to do.
    Good Luck.
    Link to VOBMerge
  4. Member FT Shark's Avatar
    Feb 2002
    Land Down Under
    Just be cautious. You will have to split the large vob apart and author it correctly if you want it to be playable on a DVD player.
