Results 1 to 9 of 9
  1. My problem is that 23.976fps films have jerky video. Here is what i do:
    1. check for bad frames and remove if necessary (vdub-mp3-freeze)
    2. extract audio to wav (convert to 48000 if necessary) (goldwave)
    3. use tmpgenc wizard to encode audio and video.
    This i think is the problem, i choose NTSC as there i cannot find a 23.976 option. Is this the cause of the jerkiness and if so how can i fix it.
    This has only happened on 3 occasions, but i always use the same method.
  2. I don't use the wizard in tmpgenc, so can't help with that, but setting things manually here is what you need to set (and in this order too!).
    Settings->Video tab
    Encode Mode, 3:2 pulldown whne playback
    Frame Rate, 23.976fps (internally 29.976fps)
    Settings->advanced tab
    3:2 pulldown OFF
    Do Not Framerate conversion OFF
    Choose ntsc and change to ntsc film(23,976 with 3:2 pulldown)
    step 1,2 and 5 under Settings:
    I lost
  5. many thanks. I am trying it now.
    Would this be the cause of the jerkiness?
  6. Originally Posted by gemmell
    Probably
  7. Originally Posted by Baldrick
    I lost
    It was all the extra time spent digging out the screenshot from your obviously large archive of such items
  8. i think this might just help me, i never thought much of the whole 23,976 thing, i just rounded.
  9. Does this method keep the audio in sync. I had a few clips that were 23.976. i converted them to 29.97 so i could burn as dvd-vcd and the audio remained in sync. but on some the audio was off. i have tried everything but cant get the audio to sync.
    so with this method i convert the video to .m2v and use the wav audio i got from the original avi using vdub and then mux them together with tmpg?
