I'm new with this whole VirtualDub program could anyone teach me on whta settings i should do, what codecs i should use, what are filters and i've been hearing about frame drops, should i do that and if yes how?. I'm using a AMD1.2ghz 320sdram 15gb 5400rpm HD Matrox Marvel g450 etv (similar to ATI AIW). thanks!
http://www.vcdhelp.com/mjpeg.htm
http://www.doom9.org/virtualdub_procedures.htm
VirtualDub is a very flexible program. You can use it to capture analog video. Also you can use is for video editing.
What do you want to do? -
ok thanx! i'll try it. I plan to use it for capturing and editing. Also, i downloaded a new codec, DivX 4.01, is it good? what settings should i use?
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 15:50 -
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 21:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
virtualdub vs others
By dude112 in forum Video ConversionReplies: 13Last Post: 13th Nov 2008, 22:49 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
