I used Tmpgenc Plus to encode an avi file to Mpeg-2 and the resulting mpeg-2 file had no audio. The original avi file has AC3 5channel audio.
Do I need to extract the audio first and then link it when wuthoring the dvd?? I used Tmpgenc DVD author to create the video and audio folders and convert the Mpeg-2 file.
What method should I follow to deal with avi files with AC3 audio in order to keep the AC3 audio on the final DVD.
https://www.videohelp.com/forum/userguides/186739.php
You don't have to encode again, just use your mpg and select the ac3 source in tmpgenc dvd author. -
Originally Posted by Baldrick
Thanks a lot! I will use the guide you suggested.
MPEG Streamclip / Converted WMV to MPEG-4 but only got the audio? Help me.
By aka_director in forum Video ConversionReplies: 0Last Post: 3rd Oct 2010, 22:24 -
VOB2MPG (converted MPG file has no audio!)
By sonicdeth in forum SVCD2DVD & VOB2MPGReplies: 28Last Post: 5th Jan 2010, 19:23 -
Converted mkv file can't keep DTS audio
By thegrube in forum Video ConversionReplies: 4Last Post: 11th May 2009, 14:49 -
No audio in converted file
By seaneroni in forum ffmpegX general discussionReplies: 5Last Post: 27th Apr 2009, 22:25 -
audio in converted file is not good
By sumeshkri in forum Video ConversionReplies: 3Last Post: 15th Feb 2008, 02:43
