I load some .vob files to the asset window. They are of the same movie. When I drag the second file up to the movietimeline it sais that I already have a movie there. What should I do to brang all files up in order.
Results 1 to 12 of 12
Originally Posted by Finfarin
Actually, I can't seem to figure out how to select anything other than a DVD or CD ROM drive as the source in DVD Decrypter. That said you could still just burn the VOB files straight to a DVD (i would use a DVD RW disc that way you don't waste a DVD R disc), then use DVD Decrypter to rip the files from the created DVD back to your HD as one VOB file.
Finfarin wrote:
Does it work even though the vob files are on my computer and not on a cd.funkguy4 wrote:
Indeed it does -
Did you try SmartRipper?
I think when you load the VOBs as assets and let it demux , it
does the whole set -
Originally Posted by funkguy4
I think FOO has the right idea.
Also, if you do not want to re-rip or make one large VOB or demux for that matter, add each movie clip to it's own MOVIE box. Then, connect the end of the first with the beginning of teh next until all the VOBs are connected. -
Watch what it does when you add a VOB in % progress . It doesn't show
all of them , but it is reading them all -
Originally Posted by andkiich
Autoring with DVD Lab
By mogoyon in forum Authoring (DVD)Replies: 4Last Post: 12th Feb 2010, 11:08 -
Help with DVD Lab Pro
By blacksheepdownunder in forum Authoring (DVD)Replies: 12Last Post: 31st Dec 2009, 23:01 -
DVD Lab Pro
By Flying Doctor in forum Authoring (DVD)Replies: 6Last Post: 16th Jun 2008, 09:00 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 07:53 -
DVD Lab Help!
By ardiani in forum Newbie / General discussionsReplies: 14Last Post: 25th May 2007, 07:52
