I already have a JVC VCR w/ internal TBC, but I have heard they don't do the same thing as a real TBC. I have been told that they are just a simple variable line delay which solves jitter off of the tape, but is not a full frame storage TBC. I don't have video capture problems, but I do have some audio sync issues with old tapes (quickly going in and out of sync in the same spoken sentence). This happens on my PC capture card and on my stand alone DVD recorder. I have been considering 3 TBCs. The AVT-8710, TBC-1000 and the ACE Converter. The problem with the AVT-8710 is that I have heard some people claim it doesn't work too well. I wonder if it is really a full frame storage TBC like the ACE and TBC-1000. The TBC-1000 has the problem of having no adjustments at all. The ACE (gthelectronics.com) has many more features than the others: White Balance, Color Balance, Horizontal and Vertical color shift, contrast, brightness, saturation, converts PAL/NTSC/SECAM to any standard, does audio and video fades, has YUV output via SCART, is a full 8Mbit full frame TBC, and has several zoom and aspect ratio adjustments. Many of these features I don't need, I mainly need the TBC, and zoom adjustment (my 16:9 TV has a design flaw and expands vertically by 50% instead of the correct 33% when trying to expand a 4:3 letterboxed image to fill the 16:9 screen). However this device is VERY expensive....approaching $500. I have found several opinions of the TBC-1000 and AVT-8710, but I have not seen anyone mention the ACE. I am a bit nervous spending that kind of money on the device. Does anyone have this device and can share their opinion? Thanks.
One vote for DATAVIDEO TBC-1000
Even the SIMA SED-CM is good for weak usage (like frame drops).Want my help? Ask here! (not via PM!)
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 20:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 09:29
