Hello friends, I need HELPPPPP!
How to convert Mpg1 to Avi without get a enormous avi file.
I have an Mpg1 move and i need to add subtitles an I don't know how.
I tried the with Virtual Dub but with the Frame server the TmpG encoder don't recognise the .vdr file.( Unknow file format).
So, please help me. Is there anyway to recognise the file? Can I add the subtitles directly to the MPG1 without convert first to Avi.
Kind Regards,
Have a look at the virtualDub directory, click on AuxSetup.exe, install the handler.
TMPG accept .vdr files as video source.
Get Gabest' vobsub if you want to have subtitles. Extract it to Vdub\plugin subdirectory and rename the .dll to .vdf.
zola, I could not reply by email. Which error message have you got exactly?
Go to option> enviromental setting> VFAPI plugin and change the priorities of the file readers. Probably Direct show must be set to highest priority. Also try to run Proxyoff.reg before starting the frameserver. I know, the guide says run Proxyon.reg, but it isn't necessary since TMPG accept .vdr files. -
On 2001-10-15 08:37:50, Truman wrote:
..hmm, why to use a compression codec, if I can frameserve?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
hmm, i dont bother with frameserving because my computer does not stay up enough for the whole process to complete (IT TAKES AGES) i mean 2 continuos days atleast -
Hello friends. I need help abou something I tried many times
with virtual dub and TMPg encoder with no lucky.
I have an mpg1 file an i need to add subtitles to this file.
Explain me the best, fastest and simply way to do it.
I've got the subtitles in .ssa.
Tank you,
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 19:14 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
avi to mpg1
By zoranb in forum MacReplies: 3Last Post: 12th Sep 2007, 14:46 -
Minimum MPG1 file size?
By Choppa in forum Authoring (VCD/SVCD)Replies: 17Last Post: 17th Jun 2007, 23:04
