I know this must be a simple question but I don't know the answer.
I have a pioneer a106. I am going to make my own dvd from home movies. Do I have to set the region in my burner. I says that I can only change it 5 times.
Thanks in advance.
Everyone have a good Holiday.
CaT
Region codes are for playback/reading only. And usually only used by companies releasing films on DVD so they can control where which film is released first. Very narrow minded and ancient history if you ask me, but then again Hollywood is still old fashioned in some ways.
I haven't set my region yet and am making DVDs without problems.
Only set it when you want to play a film or something that is specifically made for a certain region. There are by the way ways to make your burner/reader multi-region... just don;t ask me howCheck the internet
No, you only need to set the region if you want to play a region encoded DVD in the drive.
thanks for the reply.
As long as I don't play them in the dvd burner I'm Ok.
CaT -
If I have two dvd drives in my computer, a dvd-rom and a dvd-burner, can each drive be set to a different region?
TANSTAAFL -
just use software like http://www.slysoft.com/en/ or dvdregionfree and all your drive's will be region free.
Being able to set region code in LG BD550 blu ray player
By bevivek in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Oct 2011, 06:11 -
Can a tv re-set a region-hacked dvd player?
By Monkey69 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 6th Jun 2011, 11:21 -
LG550 - want to set to multi-region
By Mexxy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Jul 2010, 20:20 -
DVDDecrypter wants to set Region Code
By src2206 in forum DVD RippingReplies: 6Last Post: 15th Feb 2009, 11:38 -
DVDdecrypter region code not set. Help
By X_Splinter in forum Software PlayingReplies: 2Last Post: 9th Sep 2008, 17:08
