  1. i've installed full version of svcd2dvd but when i go to extract the reg[1].xml it says no archives found so then i tried to explore the file it then says the compressed folder is invalid or corrupt then i tried opening it to have a look and it said archive is either unknown format or damaged!!!
    is it possible that the attachment i was sent is the problem?
  2. Guest
    Try winzip. (i use v 9)
    If you have an issue drop me an email & I'll resend.
    CB
