been trying to get to there sites withe no luck...is it my ISP or is there something up?![]()
Results 1 to 14 of 14
Dead here
still can't get to the site....but i can access it at my office (T-1)...something about a DNS problem?...bump.
OK from the UK
just tried again...no dice...what is a DNS problem? as i can access the site from my office and some people are having no problem?
If you are using Win XP or 2000, try flushing your DNS cache with the following ...
From the command prompt type: ipconfig /flushdns
Try accessing it afterwards.
Also -- if you know the IP address of the website (dvdcoverart is 207.44.184.122 and DV-Depot is 207.44.184.121), type it into your browser intead of the URL and see if you can access it. They appear to be owned (or at least hosted) by the same company as their IP address is only 1 apart.
If the website has changed their IP adress (i.e. changed hosting company, etc.) it can take several days to a week for the new DNS entry to propogate to all DNS servers across the internet.
DNS is what resolves the domain name www.dvdcoverart.com to the actual IP address for that site. As for being able to access it from the office -- it is proabably that your employer has their own DNS server or uses a different ISP's DNS server which has the correct entry in it's DNS table.
This site is helpful in resoving a URL to the actual IP adress, in addition to other things ... http://network-tools.com/
BTW -- I cannot access it with the URL either via Comcast. -
When these sites charge you for downloading a DVD cover aren't they breaking the law. Aren't they charging for distributing copyrighted material which they clearly do not own?
A Quote from DVDCoverArt - right on the homepage
over the past 2 days the site has been experiencing some DNS issues. Please give it another day to return to normal before emailing me with any issues
thanks! -
treid entering the IP addy only....get the site but cannot log in....where do i enter the flush DNS command?
What operating system are you running? For Win98 it would be different.
For Windows 2000/XP got to START/run and type in "cmd.exe". That will open the command prompt box. Type in the command "ipconfig /flushdns".
That's it. Although I'm not sure it will help your particualr situation as the site has reported DNS problems. Won't hurt anything though ! -
Works from here in the UK!
Had me worried - just topped up my credits before I read this postRegards,
Rob
Office Depot CD-R bad or not?
By bevills1 in forum MediaReplies: 4Last Post: 10th Aug 2010, 12:59 -
office depot's ACTIVA brand
By Tom81 in forum MediaReplies: 0Last Post: 27th Nov 2007, 19:29 -
Office Depot Brand 16X DVD
By gameroftheuk in forum DVD & Blu-ray WritersReplies: 19Last Post: 28th Sep 2007, 23:55 -
Acer 22" Wide Screen Monitor $179 at Office Depot
By ebenton in forum ComputerReplies: 8Last Post: 20th Aug 2007, 15:03 -
Office Depot brand dvd-r/ Ritek seconds?
By dnix71 in forum MediaReplies: 5Last Post: 31st May 2007, 19:15
