Even though the audio is fine before converting, it comes out as though the audio is clipped around the mid frequencies giving the speech an annoying metallic sound. I've noticed the is no longer an option for selecting 224kbps / 44.1KHz. There used to be. I don't know. Could be to do with Win XP.
Any help would be mighty appreciated!
I've just tried toolame but after creating the temporal wave file, TMPG says 'error decoding audio' or 'error writing stream' depending which version I try. Am I missing something?
OK, try this approach:
http://www.vcdhelper.com/virtualdubaudio.htm -
What is your audio source? If it is a compressed file, decompress it first with VirtualDub. From the FAQ:
first select File->Open Video File to open the video and last select File->Save WAV. If it's a DivX or ASF you maybe want to convert the audio to WAV PCM then select Uncompressed PCM under Audio->Compression and be sure to select Audio->Full Processing before saving
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
Refer to the thread listed below. I had similar problem. used ssrc audio encoder.
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=59429&forum=3
Poor Audio: Effects Loud, Dialog too Soft
By stormdragon in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2011, 19:02 -
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
Audio quality very poor in 360p...but only on some vids. Help please!
By amb in forum Video Streaming DownloadingReplies: 0Last Post: 19th Sep 2010, 14:06 -
Converting .mov file to .wmv results in poor quality?
By zenfor in forum Video ConversionReplies: 2Last Post: 6th Feb 2009, 19:00 -
Copy DVD with ConvertXtoDVD and audio speech very poor.
By swog in forum DVD RippingReplies: 2Last Post: 24th Sep 2008, 16:12
