I have a problem with converting an avi file to mpeg2.
I read in the Common TMPGEnc problems thread and i figured out what kinda of a problem i have but itīs still not working.
"or you get an empty(black) video preview window"
"Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and try reopen the video.
If that does not help be sure that you have installed DivX or XviD or MPG2 or DV Codecs, read here how to identify what codecs you need."
I have done all that but the problem is that the file says itīs unsupported but i used AVIcodec and the file isnīt unsupported.
So what can i do too fix this??
It sounds like you're trying to convert a DivX file to mpeg2 and it won't open in TMPGenc. (?)
I would try something really simple myself. I would open the file in another application, like VirtualDub, or Ulead VideoStudio, and save a short clip in say AVI/Huffy, or even convert it with VideoStudio to MPEG2.
Sometimes a small error in the video can cause problems like that. The header may be messed up. I don't know.
TMPGenc is a good program, but when something like that goes wrong I try other applications. Most of the time I find another route.
Good luck.
Handbreake & Vidcoder picture size problem (HD settings)
By Chainsaw_1 in forum Video ConversionReplies: 3Last Post: 13th Mar 2012, 12:41 -
Picture problem
By Kurtis in forum Newbie / General discussionsReplies: 6Last Post: 30th Oct 2011, 22:06 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
scrolling picture problem with svideo
By slyder0244 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 21st Jun 2009, 19:35 -
Oppo 980 problem--losing picture
By mel33 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 3rd Jan 2008, 10:33
