Astrum!
I'm using DVD Maestro (Which i must add, is an Amazing Authoring Software, absolutely Brilliant) ... to author my DVDs.
I was able to successfully create a DVD from my Video Files, with all Chapters, Menus etcetera. I could Compile the project successfully and even write the Disk Image to be burned to DVD.
However, when i open the "Write to DVD" dialog box, it doesn't show my DVD Burner... it only shows my Samsung CD Writer Drive.
I have the latest Optorite DVD +/- R/RW Dd burner.
I had to use Nero6 eventually to burn the DVD Project that Maestro had compiled. The DVD of course came out brilliant and plays on my normal DVD player now... But is there a way to make the Optorite DVD Burner appear in Maestro so i could write directly using Maestro?
Thanks,
Mickey
I don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
I enjoy every moment of it! -
Astrum!
No i think you're right.
Oh well, too bad. I guess i'll just be using Nero6 for final burning. Maestro is just too good at what it does, i would have prefered to use it.
Thanks,
MickeyI don't suffer from Chronic Insanity & Psychosomatic Multiple Personality Disorder!
The development of MAESTRO stopped three years ago because APPLE hired everyone at MAESTRO and discontiuned the MAESTRO product line
That said, if you purchased MAESTRO as a turnkey system (over $50,00 in some configurations) you can contact the folks that sold it to you,
and if you tell them you had to replace the original PIONEER BURNER the program can work with, they will write a driver for the OPTO DISC mechanism and send you an update. -
Known dvd-rs it works with are the Pioneer S-201 and A03. Anything else ain't gonna happen, sorry. This program ceased development in 7/2001Originally Posted by dcsos
WRONGAnything else ain't gonna happen, sorry.
Well I read that the Spruce engineers were writing new drivers for qualified recipients
What you are right about is that many people are using this software AFTER THE FACT and cannot get updates..
The Pioneer A05 is supported if you purchased your MAESTRO, its just not posted..you have to talk to APPLE for support -
Thanks guys...
DVD Recorder not recognizing dvds
By JDiane in forum DVD & Blu-ray RecordersReplies: 29Last Post: 15th Apr 2019, 15:02 -
Matshita DVD Ram UJ851s not recognizing blanc dvd
By ezradallas in forum ComputerReplies: 7Last Post: 12th Mar 2010, 12:50 -
Nero 8 not recognizing DVD burner
By JCWBobC in forum Authoring (DVD)Replies: 11Last Post: 14th Dec 2009, 23:20 -
Windows not recognizing ubs dvd writer
By coachop94 in forum DVD & Blu-ray WritersReplies: 3Last Post: 21st Jun 2007, 12:34 -
Newbie's DVD burner isn't recognizing DVDs as burnable (Both DVD+/-R)
By OhGodHelpMe in forum Newbie / General discussionsReplies: 9Last Post: 30th May 2007, 09:48
