  1. I have riped the German Version of Matrix and i won´t create a scvd with German/English audiostream. After extracting the Audiofiles with DVD2AVI i hear a delay of 10 secend in the English stream. The same movie/audio file extract with DIVX as frame server and TMPGenc as encoder are synchron???
    Have anybody an Idea?
    Feb 2001
    Kalmar, Sweden
    I don't quite follow you...
    Are both audiostreams from the DVD?
    As I understand, one is from the DVD and one is a DivX.
    German DVDs aren't the same as other countries DVDs. (Your DivX is probably from another country).
    So the streams probably doesn't match...
    Magnus Jensen
    A.K.A Geezus
  3. in the first case:
    both streams are ripped from the German DVD. It was ripped with SMARTRIPPER and then with DVD2AVI extracted. During this process cames a dalay of 10 second. If i play the DVD on a CYBERHOME M512 DVD Player works all fine, no delay!
    secundly:
    if use the ripped DVD as source for DVDX like described(DVDX as frameserver, TMPGenc as encoder) it also work correct.
    why make DVD2AVI a delay?
    is it possible that the multiangle of this Movie coused the problems?
    Feb 2001
    Kalmar, Sweden
    Could be so...
    It's been a source of problems for some people...
    Magnus Jensen
    A.K.A Geezus
  5. Schande auf Ihnen!
    Sie sollten nicht Filme stehlen.
