I want to take 3 vcd movies and put on a dvd. On the menu I want the 3 movies and I want to make a sub menu for the deleted material and other stuff for each movie. On the sub menu I want to be able to play all or have 1 file per button. How do I do this with svcd2dvd 1.5? If I can not do it with this program, what program can I do this with? Or will this be something that will be added to the program with an update?
I like the program so far, this is the only thing that I dont know about.
Also can you do some sort of chapter selection like in TmpGEnc DVD.
Jaydog_99Guest
At the moment SVCD2DVD can only have 1 root menu with a button for each VTS you make in the program.
If you want to do this try DVD-Lab. It will work with most SVCD but it hardly support VCD. But it lets you make a good menu. I know play al can be done but you need to look for a guide on that cause it isn't strait forward.Greatings,
Yf -
Jaydog_99Guest
Can you create a menu like the one I want with dvdlab and then import it into svcd2dvd? Or with any other program, I see you can load a menu in svcd but it is looking for a xml file.
Maybe the company could add this type of feature to the next release or update. Im sure that im not the only one that is wanting to do this type of project and I love the ease of the svcd2dvd program, so it would be great to be able to do it all with this one program. -
No you can't, at the moment you can only load old menu's not hand made onces.Originally Posted by Jaydog_99
The company that sounds funny, cause Chrissyboy is the one that is making the program. I think he can put it on his wishlist.Originally Posted by Jaydog_99Greatings,
Yf
Zealsoft Music DVD Maker question
By mysts in forum Newbie / General discussionsReplies: 9Last Post: 15th Sep 2008, 08:33 -
DVD Menu Maker
By ozab in forum Authoring (DVD)Replies: 1Last Post: 30th Apr 2008, 21:49 -
Question Windows Movie Maker
By crowheart in forum Newbie / General discussionsReplies: 3Last Post: 16th Mar 2008, 14:14 -
fraps, windows movie maker, x264 question
By combatsimulation in forum Video ConversionReplies: 0Last Post: 20th Jul 2007, 15:21 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 23:18
