Nero save cd images to .nrg , i need a software to save directly to .bin for use the images with SVCD2DVD.
How ?
Hi, Nasp!Originally Posted by Nasp
Use VCDGear which is freeware and can be downloaded from: http://www.vcdgear.com/download_gui.html.
This is the Windows GUI version. There is a DOS version inside the SVCD2DVD application Folder, but DOS command line programs are notoriously difficult to handle.
Hope this helps.
Callan -
You can also use .mpg. It supports cue/bin cause that is the most used methode of images for svcd and vcds.Originally Posted by Guest
NOTE: why was this double post? please don't do that..Greatings,
Yf
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 08:13 -
extract music from bin image?
By pensioner in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2011, 00:01 -
Printed page image don't equal PC monitor's image?
By bryankendall in forum Newbie / General discussionsReplies: 9Last Post: 11th Nov 2008, 14:45 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 05:29
