Four days ago I purchased a Lite-On LDW-411s at BestBuy for $79.99.
It came with a 4x +R and a 4x +RW.
The biggest difference I have noticed so far is that on my DVD-R's and -RW's I had done on my Pioneer 104, they would not play on my home set-top Philips 711 or Toshiba 3950 UNLESS you had more than 3.9 to 4 GB on each disc.
The nice thing about the +R's and +RW's is that no matter how little info I put on the disc for file size, both types play on both of my set-top players.
A small 1.2 GB little snippet of a movie plays with no problem.
I thought that this would be interesting for anyone with a dual format burner in case they had the same problem to help them choose the right media.
So I guess my conclusion is to use the DVD+ media for smaller files and the - format for the larger files.
If this isn't in the right forum please feel free to move it.
Tom
This is a known issue with the Phillips 711, actually -- it seems to be a bug in the firmware which hasn't been fixed.
Why +R media gets away with it when -R media doesn't is less certain, unless it has something to do with the way that some +R burners and burning software "lie" about the book-type code when burning +R media to increase the odds that older players will recognize the disc.
In any case, I've burned -R and -RW discs with as little as 200Mb on them and had them play in a variety of set-top DVD players, so this is very much a matter of "whatever works for you."
What did you burn 200 Mb and get it to work with ? Burner, I mean.
Cause while I know it is an issue with the Philips , it seems odd that it would continue 3 years later with a brand new model, my Toshiba.
Maybe it was just discs burned with the Pioneer. Next time I buy some fresh -RW's that haven't been burned on yet I'll try the Lite-On and see if that is the diff. -
The burner was a Pioneer A-05, burned onto TDK DVD-R and -RW media. The software used was ULead DVD Workshop.
The resulting discs play fine in my Apex, and in several models of Sony owned by various friends... Interestingly enough, the -RW copy did not work in a friend's Philips DVD+R set-top recorder, though the -R copy did. Go figure. -
I have numerous test clips from 10 Mb up to 4.3 Gb and they all play in both my players , + or -, R or RW. My Apex will do ISO's, so that's easy, my #2 won't so I have to Author, but never had an issue.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
general conversion advice (blueray and dvd)
By ripit in forum Video ConversionReplies: 5Last Post: 16th Feb 2011, 07:24 -
burn MP4 AVC H.264 to play on general DVD player
By surfers in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2011, 08:44 -
few general questions about dvd converting
By kobi_af in forum Newbie / General discussionsReplies: 11Last Post: 25th Nov 2009, 17:19 -
General information on how DVD players and their firmware (or software)
By Samazama in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2009, 17:51 -
General DVD player problem.
By Ba745 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 27th Jun 2007, 05:20
