Every time i try to capture i get a failure notice and the program shuts down. MyDVD, Ulead6, Sonic, etc. Any ideas?
It's drivers. You are missing the needed drivers. You need WDM drivers, not VFW for those apps. A TWAIN driver helps a lot also.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
but it had been working perfectly for quite awhile then all of a sudden. It does it when i click "new project" and it starts to go to the capture screen. I reinstalled my drivers but no luck. i'm going to see if there is a newer driver on the ati site...in the meantime..help
i found a error log that says:
*** Log Manager 0: Opened on: 12/27/2003 [17:54:29]
[17:54:35] ResMngr::LoadObject CoCreate Error: ClassNotReg CLSID: {B6761AC7-0F95-4184-8CEE-0E8495BEBD13}
[17:54:41] TvDisp: StartUp: Failed to setup DTV Graph
[17:54:50] CDispControl_DS:ApplyCropFactor: Failed SetSourcePosition x=21, y=16, cx=677, cy=508
*** Log Manager 0: Closed on: 12/27/2003 [17:55:28] -
Installed or uninstalled any software lately? It almost looks from the log that one of the classes needed for the program is either no longer registered in Windows registry or has been deleted.
You might just want to re-install the programs that are crashing on you, see if that helps.
Are transcoding AV-sync errors caused by hardware or software?
By MarcMiller in forum Video ConversionReplies: 14Last Post: 6th Dec 2011, 15:44 -
Getting Macrovision errors on home tapes - what software can help me
By elcondor in forum Capturing and VCRReplies: 0Last Post: 16th Nov 2009, 06:54 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Is there Any software that will correct for tracking errors on a DVD?
By hitechluddite in forum DVD RippingReplies: 7Last Post: 19th Jan 2009, 11:32 -
Cannot get any avi to dvd software to work (various errors)
By gally56 in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2008, 12:09
