  1. hi, I have a VCD file which is NOT Vcd Standard:
    352x240
    2 pass vbr - 300-2200
    44100 - 192 audio
    29.97fps
    All I want to do is add chapters, when I add the file to VCD easy, when I go to make chapters it says the in red letters: "Number of possible entry points = 1".
    So I can't make chapters? Is this beause it isn't a standard VCD.
    PLease help..
    Is there any other program I can get that will add chapters and not encode the file as well?????
    I'm dying here...
    Dec 2002
    Costa Rica
    I have done that with Nero 5.5.
  3. there is something wrong with your mpg file ... try demultiplexing audio aND VIDEO then mutiplexing them with say tmpgenc this should allow 100's of entry points.
    The electronic components of the power part adopted a lot of Rubycons.
