Ok, Ok, I downloaded CD Wave Editor upon advice from another post. I want to splice together a few audio tracks (wav files) to create one wav file (probably ten songs or so)...
So, how do I do it?
I drag one wav file to the interface of the editor, and see it there. I see the prompt to split, I do that, but how do I add another file? Good grief, could the FAQ accompanying the file be any more ambiguous?
You can't open up more than one wav at a time.
IE: My project involves recording the entire side of a tape at once, then break them up. You can split any length of wav into multiple wavs then you save each one.
Only problem is that it saves the original, unbroken wav and sometimes it splits songs at low parts of the song. You should also get a batch MP3 encoder so you save on space by converting the wav. -
open a dos box and add your files using standard dos commands for appending files all your wavs should be of the same ilk .
If you are going to be mixing alot, take a look at what I have
found is one of the easiest pro editors out there
- Adobe Audition (used to be cooledit pro)
[Q] good audio editor
By Csubakka in forum AudioReplies: 4Last Post: 27th Nov 2010, 11:28 -
Can anyone recommend a good AVI editor?
By djdust in forum Newbie / General discussionsReplies: 48Last Post: 17th May 2010, 14:46 -
Giveaway of the Day - Gold Wave Editor Pro
By VirtualDoobMon in forum AudioReplies: 1Last Post: 23rd May 2009, 08:25 -
Good editor? (Freeware)
By chronic777 in forum EditingReplies: 10Last Post: 23rd Jul 2008, 15:22 -
Can Anyone Recommend a Good Audio and Video Tag Editor?
By Nitro89 in forum ComputerReplies: 1Last Post: 23rd May 2008, 03:16
