Ok, here is the problem, I've downloaded The newest version of BeSweet Because I need to convert AC3 or WAV to MP2. Now, I've read that I can do it with a program called LAME but I didnt find it in BeSweet so I downloaded it and used the BwSweet GUI to work with it, now the problem is that I dont have any profiles with this "lame" program and I can only convert WAV to MP3...Any Ideas anyone?
What can I use to convert AC3 to 224k 44.1MHZ MP2 file (for VCD)?
Select mp2 as your output type and when you go to select your ac3 just make sure the selector in the upper right corner of the file browser says ac3.
besweet, belight
By volam in forum AudioReplies: 0Last Post: 9th Sep 2009, 20:53 -
Besweet causing problems?
By hardcorejason in forum Video ConversionReplies: 1Last Post: 27th Apr 2008, 13:59 -
besweet 5.1 wav
By dvdfreak1971 in forum AudioReplies: 1Last Post: 11th Apr 2008, 14:44 -
BeSweet Volume Drop
By rixware in forum AudioReplies: 8Last Post: 26th Feb 2008, 23:43
