I've looked around but can't find out a great way to rip just the audio from a DVD to wav. I have a few Comedy DVD's and a few Musical DVD's and would like to rip the audio so I can burn them for listening on CD. Anyone know how to do this?
tb
use dvd2avi and make save project file. it will make a .d2v project file, which you will not need, and a .wav file. (requires that u rip the vobs first)
Alternatively, rip all the VOB files and with relevant IFO file. Then load up the IFO with FlaskMPEG 0.6 (the newest revision) and select the soundtrack of your choice.
Then use the "audio player" option to write the soundtrack as a wave file.
Regards.
Michael Tam
w: Morsels of Evidence -
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
... as the "Extract WAV" feature alone did not work for me, I've found.
You probably would have to open up in the audio player to extract.
Thanks for the help. I found the best way for me to do it is to rip with SmartRipper, encode with DVD2Avi, and just keep that WAV file.
-Tim
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 08:39 -
How to rip dvd audio to mp3 or wav files?
By babypotato in forum DVD RippingReplies: 12Last Post: 17th Jul 2011, 04:22 -
Convert MP3 -> WAV, Copy to HD and RIP
By ctdvd in forum AudioReplies: 4Last Post: 23rd Jan 2010, 07:32 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 02:47 -
rip DVD music to Wav
By fabioacer in forum DVD RippingReplies: 6Last Post: 19th Jun 2007, 15:37
