Having some trouble with TMPGEnc. I am trying to take an mpeg and split it into tow seperate files. I managed to take the file and output it to the first of two files without a problem. Then I went back into TMPGEnc and slid the slider bar half way (right where the first file ends) and when I hit Run, I get an error after a minute or so.
"Illegal mpeg video stream"???
Anyone know what could be going on?
I've had this kind of problem using TMPGenc and I gave up all together. I now use Boilsoft AVI/MPG/ASF/WMV splitter found here:
http://www.boilsoft.com/videosplitter/
Great little app by the way. Sorry this isn't exactly a solution to your TMPGenc issue. -
I remember the older versions had this problem. If you have the latest version, try using the Source Range function. It is more user friendly.
Hello.
Splitting a .TS file in half
By danielmak in forum MacReplies: 4Last Post: 1st May 2011, 01:19 -
Splitting TS-file with tsMuxer creates lag in end file
By Prospero in forum EditingReplies: 6Last Post: 20th Apr 2011, 17:44 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 09:18 -
splitting a iso file
By brenjim in forum Newbie / General discussionsReplies: 13Last Post: 8th Apr 2008, 10:49 -
Splitting avi file
By tryst1 in forum EditingReplies: 2Last Post: 15th Nov 2007, 04:33
