    Sep 2003
    Big Apple
    I don't want to install a codec pack because it messed up my system a couple od times. I dl a lot of movies and most of them I can't play right now. Can someone please tell me which codecs I need to get to play movies.
    Apr 2002
    The State of Frustration
    Once the movie is loaded on your system, use GSpot to tell you what codec you need for that particular movie.
    Hello.
    Sep 2003
    Big Apple
    I checked one of the movies with gspot and it says I need Xvid. I checked on the page with codecs and found xvid codec https://www.videohelp.com/tools?tool=190#comments
    is there a difference between Koepi's and Nic's codec
    Apr 2002
    Not to my knowledge. You can try them one a t a time and see which one works for you.
    Hello.
    Dec 2000
    Bumblepluck, NY
    One at a time? How do you unistall them after installing them. Not just these 2 specifically, but in general how can you check which codecs are on your system & then remove all that you dont need ( I'm getting another pink screen issue that won't quit)
    Apr 2002
    You uninstall them from the hardware device manager.
    Hello.
    Dec 2000
    Bumblepluck, NY
    Ok, I know how to get to the hardware device manager, but... then what?
