Hey Guys-
I have a bunch of .avi files that I would like tog et onto 1 DVD. They range in size form 150mb to 450mb. I made a disc just dragging them into Toast 6 but that goes by the length of time not file size. Anyone know a way to do this>
Thanks!
Import em with Toast, save as image. then shrink to fit with DVD2oneX.
Note that the file size of the AVIs doesn't relate to the filesize of the finalized DVD footage.If it isn't broken, take it apart and find out why.
blog: deadsierra -
I think you're trying to make a video DVD ... Is that right? Or just a straight data DVD-ROM with your AVI's as AVI?
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27 -
Multiple AVI file for one DVD
By tim_ver in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jan 2009, 04:45 -
multiple AVI to DVD (definately resolved)
By exekutive in forum ffmpegX general discussionReplies: 60Last Post: 27th Dec 2007, 14:22 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28 -
Multiple AVI's to DVD ????
By paulwilko in forum Authoring (DVD)Replies: 3Last Post: 5th Oct 2007, 05:30
