I received mine yesterday and gave it a little try to make sure it worked fine before I gotta wait to really get it on christmas, only had it on for an hour and when I went to put it away it seemed abnormally warm to me in comparison to other things that I've used before. Just wondering if the advc-100 does generate a lot of heat from someone with experience with it. I'm sure this isn't anything to worry about but just wanna make sure before I really start using it. thanks.
I've had mine about a month and no, mine doesn't appear to generate an inordinate amount of heat.
I'll check it next few days and report back.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Depends what you mean by warm. Mine feels as warm as the back of my PC monitor - maybe slightly cooler (monitor is on 24/7 - stand-by set to 30 mins).
Regards,
Rob
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Microsoft DV Camera and VCR/ Canopus ADVC 100
By BonnieW88 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 18:26 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 09:39 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 19:24
