  1. HI all
    I have downloaded a file which i thought was a bin/cue file but it turned out to be a rar file containing a Folder named Data Folder inside that a 650m file with the ext .dat seg. Also in the rar file are two small unknown files which are called desktop db and desktop df
    Can anyone tell me what these are and how to burn
    Sorry if a have not posted in the correct forum
    Dec 2002
    .DAT is VCD, you can use VCDGear to convert the .DAT to .MPG , takes about zero time (it's more of a header trick than true conversion).
    You can then use NERO to burn a VCD and drop in the MPG. I'm not sure if it will burn with the .DAT or not, you can try it and see if it accepts it?
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
