I just got a nice NTSC VHS tape which i want to capture with my Pinnacle Studio Deluxe card (using Studio 8 as software).
My VCR is PAL, but it can play NTSC tapes, only it converts the signal to PAL60, which makes it perfectly playable with colours. But, when i try to record this with Pinnacle (PAL or NTSC) it's black and white.
Anyone knows how to solve this? Perhaps some hacked Pinnacle drivers? I already found some other drivers that supposed to work with VirtualDub, but as far as i know these are BTxxx drivers designed for TV tuner cards like the PCTV Pro.![]()
Does your VCR plays NTSC as NTSC by any chance ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
First of all, you need to install the latest tweeked WDM Capture drivers & WDM Capture utility
Then, you have to install the latest dscaler and the latest virtualvcr
Now: You open dscaler and set PAL 60 as source. You exit dscaler. You load virtualvcr and you change the device settings to PAL60 (if you don't run first dscaler, this option ain't always there for virtualvcr...).
You set manualy framerate to 29.97 and you resample audio. You also set capture size at 704 x 480 (NOT 704/720 x 576)
You grabb...
You filter and you encode using TMPGenc, as NTSC not PAL.
Problem: Sometimes the audio is out of synch. Solutions:
1. Grab 10 min segments (not more!). IMHO the best solution. The audio delay is there, but it is not enough to be noticable.
2. Set the framerate to 30.00 Fps. Unfortunatelly, you have to convert this to 29.97 or 23.97 using various technics, mostly for NTSC. Then, you do a framerate convertion using virtualdub (or avisynth). The audio/video is OK but there gonna be some fields here or there "jumping" in the picture. This sometimes can be really anoying but most of the time is simply unoticable.
Unfortunatelly, you can't capture PAL 60 with virtualdub using wdm drivers and vfm wrappers. You can't set the input to PAL 60: When you install WDM drivers, the program ask you what system you use. What you set there, is what sticks with virtualdub.
If you use win98se and vfm drivers you may be able to grabb PAL60 with virtualdub. I did it once some time ago, but it was really difficult. -
Originally Posted by SatStorm
I don't have problem on capturing PAL 60 using Hauppauge win TV primio FM and Kworld Mpeg 2 Station, with the latest BtwinCap 5.3.7 and the method above. I also set the framesize at 704 x 480 and the framerate at 29.97 to succeed capturing without any frame drop. On some videos, this must be set to 30.00, so if you drop lots of frames, set it to 30.00 and it might stop.
You don't use RF right? (tuner) Only with S-VIdeo / Composite-In connection, this option is avalaible.
If you have a colour picture with dscaler on PAL60, then it is possible to capture for sure. You just need to find how to set up your card right. To force some capturing applications work with PAL 60.
I also remember unlead movie factory 1 succeed PAL60 captures with my asus 7700 card, which is an nvidia card. There, I had to use the old good WDM 1.08 drivers (the only ones work with that card....)
Finally, there is always the possibility your card simply can't except anything else than what you bought it for...
Isn't silly? A cheap 50 Euro card can do things an expencive 300 euro can't. -
anyway, Thans for the help, I let you know if I found something that works
Koen
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
MP20 Capture Card and Pinnacle Studio 14
By egee17 in forum Capturing and VCRReplies: 0Last Post: 26th Feb 2011, 19:30 -
Can I capture DVD to edit? Pinnacle studio 12 ultimate
By photonianpa in forum EditingReplies: 1Last Post: 5th Mar 2009, 05:29 -
Pinnacle studio 11 capture problems...
By bla4free in forum Capturing and VCRReplies: 0Last Post: 6th Feb 2008, 10:09 -
Pinnacle studio 8 capture problems
By bimfi in forum Capturing and VCRReplies: 1Last Post: 23rd Nov 2007, 15:27
