I have an avi file and with virtual dub (and the avert lee subtitle filter) I add permanent subtitles to my movie. The movie is in 16:9 format, but the subtitles is still shown in the picture.
Is it possible to move them down so the subtitles appear on the black bar in the bottom of the picture?
If you add resize filter first (and letterbox to the correct aspect ratio), and then add the subs filter, the subs will be (at least partly) in the black bottom border.
/Mats -
You have to help me a little more. I dont seem to find the right aspect ratio.
FIRST i add a resize filter.
Then I check the box "Expand frame and letterbox image". But then I cant find the right aspect ratio.The movie is 576x320.
Hope you can help me...?
Sorry... now I have found! Thanks for helping.. -
Great! Hope it works. Getting stuff in the right proportions may be very complex, with various resolutions, DAR and stuff...
/Mats -
Which sizes do u use with the filter for making a wide screen movie with the subtitles beneath them in a black box ??
Grtz. Gaston -
It all depends on the w/h of the AVI, and if you want to do anamorphic, 4:3 or 16:9 output. Usually I just weat my finger, put it in the air, and make an educated guess!
(Hmmm - they look a little squashed now, but when I set the telly at 16:9, I think they will look about right - let's try that!) It usually works. I've seen much worse resizing on national TV in every case so far...
/Mats
How to move subtitles on the screen with Subtitle Workshop
By Lun in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2010, 18:31 -
Possible To Move Subtitles Up
By rock99 in forum SubtitleReplies: 0Last Post: 12th Mar 2010, 05:51 -
ulead dvd move factory, subtitles
By brenna_AK in forum EditingReplies: 0Last Post: 12th May 2009, 00:30 -
Move subtitles upwards
By joelson in forum SubtitleReplies: 3Last Post: 11th May 2009, 07:36 -
How do I move subtitles to an unused space?
By darkzero297 in forum SubtitleReplies: 5Last Post: 14th Aug 2007, 07:47
