  1. It's available via versiontracker. Haven't tried it yet, so can't comment.
    william
    Jun 2001
    Silver Spring, MD USA
    From DVD2One.com, the new release of DVD2oneX contains the following features:
    Added cell/chapter/layer selection for movie-only and join mode.
    Split a long movie over 2 disks using layer selection in movie-only mode.
    Compile 'best-of' clips disks using cell/chapter selection in the join mode.
    Changed input file IO for movie-only and join mode to random access based on IFO files.
    This improves speed considerably in combination with the new cell/chapter/layer selection.
    It also speeds up selection of one title from a vobset containing multiple titles.
    Added check to verify whether the VOB files match with the IFO files.
    This avoids possible strange and unpredictable behavior of the program.
    It also avoids incorrect destination size calculation in case the IFO and VOB files do not match.
    Fixed a small bug in the seamless join of a titles with multiple angles.
    Fixed the problem that an illegal value in the Audio Info field in the IFO file could crash the program.
    Fixed a small problem with default subtitle selection in movie-only mode.
    Jun 2001
    I discovered a small issue with this version. I was playing around with the chapter features, and I had it cut out a chapter from a movie. My destination drive had fewer than 4.4gb of space available, so the software refused to write the <300mb chapter as a new DVD. Once I switched to User Defined size and input a number under 4gb (the space I had available), the new VIDEO_TS folder was written just fine.
  4. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Excellent, this sounds like a great update. I can't wait to be able to try the layer break splitting across 2 DVD-Rs and chapter support. AntnyMD, that doesn't sound like a big problem, but I hope you let the developers know about it. Thanks for bringing it to our attention, though.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
