I hope someone one can help me out. I have just used SHrink to back up both discs to The Godfather part 2 and I want to add them both to only 1 disc. I tied dragging both of their VIDEO_TS folder, but they are both label "Title 1." Does anyone know away I can get it to work? TIA
Thanks, Will. I tried it, but whenever I dragging in or open files for the second disk it overrides the first disc.
You could use TMPGENC DVD author to join the two discs. If you are ripping movie only, just select the first disc's movie only titleset, then the second disc's movie only titleset when you import dvd video into the program. TMPGENC will join the two parts of the movie without any gaps. You can't keep original menus, but you can create a basic menu and keep the original chapter information.
I got the Godfather DVD set for Christmas. i would like to also back them up. This is my plan. Does it sound OK?
Movies 1 & 3 I extracted using DVd Decrypter and split them using IFOedit. Two disks for each movie. I also created an .ISO to use to burn with DVd Decryper.
Movie 2 is a little more complicated. I extracted both disks with DVD Decrypter and use DVDShrink to shink them both to the size of 2 DVD-5's... 10.5GB to 8.8GB about 80%. Then I use Deep Analysis and then "backup". After it was done, I thought I could use IFO edit to split my newly joined movie but it will only allow me to split each seperate group of .VOB's. DVD Shrink made two sets of .VOB's, one for each movie part. What else can I do to split this movie to two disks now? I'm lost.
Thanks in advance,
Mike
cant find DVD titles ....
By cooolman in forum DVD RippingReplies: 8Last Post: 26th Mar 2011, 11:46 -
DVD Architect - chainlink titles
By couchdirector in forum Authoring (DVD)Replies: 3Last Post: 28th Jul 2008, 13:13 -
Need help with adding titles, credits and music to an avi
By dpoon in forum Newbie / General discussionsReplies: 1Last Post: 4th Feb 2008, 15:06 -
adding sub titles
By dickdb in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 13th Dec 2007, 19:30 -
Adding animated titles
By SearchQuality in forum EditingReplies: 8Last Post: 30th Nov 2007, 19:27
