I was wondering what are the really advantages of paying 2x just to have a HD?
Is it really a must have or can I live without it.
I will be buying a recorder soon, but i havent decided which model yet.
Besides the HD is there any other important feature I should consider?
Regards,
Reco
Editing is one advantage. You can edit post recording. You can also decides whether or not to keep your recorded programming for posterity after it has been recorded without wasting a disc. I'm sure there are many other advantages, but I can't think of any more.
Oh... if it has a built in TIVO, you can pause live tv... -
bumped..re-read post and realize he's talking about a built in HD (hard drive) in a standalone recoder. Wish there was a delete post option...
panasonics write to dvdram which is the same as a 4.7 gig HD & so you can edit on it. HD models do have a more tivo sort of thing called GUIDEPLUS, thats why they cost more, but all my TVs already have GUIDEPLUS....which is completely free.
First of all, a hard drive recorder doesn't need to cost you twice as much as a one without a drive -- it's not nearly that much to go from, say, a Panasonic DMR-E50 to a DMR-E80H.Originally Posted by SirReco
Secondly, the hard drive recorder gives you all kinds of editing options that you won't have on a non-HDD recorder. Plus, if you use it to do basic time-shifting, you can record hours and hours and hours of stuff without ever having to worry about blank tapes, blank DVD's, and so on. It's ultra-convenient.
I wrote up a good look at how the editing functions work in this thread:
https://www.videohelp.com/forum/viewtopic.php?t=192261
You might check that out, as I think it would help you envision the kind of things you could do with a hard-drive machine.
Hope this helps!
thoots
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 20:23 -
Recorder help
By thermalguy1970 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th Apr 2009, 13:59 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 05:54 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
