I just got the new version, Nero 6, and installed it on my computer. I have used the Nero Image Drive quite a bit under Nero 5.5.
When I installed Nero 6, I also installed the Image Drive - no problems. But, when I installed the upgrade to the Burning Rom software, the Image Drive was no longer available. I re-installed the Image Drive but keep getting an error saying the Driver Installation Failed.
Has anybody else experienced this? If so, has anyone found a fix?
Thanks,
Did you make sure that your previous versions of Nero and Image Drive were uninstalled before upgrading to 6? Not doing so can cause lots of errors.
Can you mount an .ISO image to a hard drive , then copy the VIDEO_TS folder
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2011, 18:11 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
Question about restoring C drive from Ghost image
By jimdagys in forum ComputerReplies: 11Last Post: 24th Aug 2009, 13:24 -
Can ImgBurn Make an Image of a Hard Drive on a Computer?
By drstew in forum Newbie / General discussionsReplies: 2Last Post: 28th Apr 2008, 07:00 -
is there a freeware tool for making an image of my c drive?
By surfmonkee in forum ComputerReplies: 17Last Post: 10th Nov 2007, 20:01
