  1. Roxio has updated their burning engine for Easy CD & DVD Creator 6. While the English version ist updated to 6.2.0.110, other languages were updated to 6.2.0.130. The burning engine is used by all components of Easy CD & DVD Creator, so you should update if you are experiencing any problems with your current installation
    Engine 6.2.0.110 update
    Fixed BSOD caused if user “Ends Task” on a Component while burning
    Creator Burn Dialog will now display “8x” for Plextor 8x DVD
    Files will now retain their date and time stamp after being retrieved with Roxio Retrieve
    For more info please go to
    www.roxio.com
    Feb 2004
    Pennsylvania, USA
    I tried giving Roxio another chance... upgraded years ago to EZCD Creator. Tried again with EZCD + DVD v6... and again I feel used, abused and ripped off. Roxio has terrible support - IF you can get them. I have never used a product of theirs to satisfaction. What a waste of money.
    Stay away from anything stamped Roxio.
