how can i burn more than on video_ts folder on one dvd-r
i use ulead dvd moviefactory
best reguards
You could do that if you burnt it as a DVD-ROM, with the VIDEO_TS folders in seperate sub-folders, but it would not be recognised as a DVD-Video by any DVD player.
The poster clicked Report instead of Reply. Here is what he said:
because i have 2 different video_ts folder (each one represent different
movie) and i'd like to join them together on 1 dvd-r
thanks -
because i have 2 different video_ts folder (each one represent differentOriginally Posted by mickle
movie) and i'd like to join them together on 1 dvd-r -
use re-authour in DVD Shrink. U can rip using something like DVD Decryptor and put one disk of the movie on the hard drive and then open the other disk, re-authour and put the two movie/video files as a new project and backup. I actually used two DVD readers to do it and put the new compiled backup to hard drive only. I then use CloneDVD on the backup to re-code and burn. U can aslo use DVD Shrink to re-code the new backup so it can fit 1 DVD-R and burn with something like Nero. I was able to put the 2 disks LOTR extended edition movies on 1 dvd+r for each movie. U'll loose the menus but then something has to be given up. BTW just remember to put the movies in their correct order when u re-authouring.
If u are trying to put 2 diff movies, then the above method may not be the best since their will be no intermission when the 1st disk ends and the start of the next disk. The backup file is only seen as 2 seperate files and are played one after the other. No stop, just a slight pause simular to a layer change on a DVD9 disk.
Burning a VIDEO_TS folder to disc makes it a playable DVD right ?
By Bansaw in forum Authoring (DVD)Replies: 25Last Post: 1st Mar 2015, 16:34 -
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 01:10 -
Avi->DVD no Video_TS folder
By gaikoku in forum ffmpegX general discussionReplies: 7Last Post: 13th Sep 2008, 13:11 -
Burning VIDEO_TS folder to a DVD disc as Video not Data
By xtaint in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 09:23 -
Using Nero Ultra: How Do I Use Video_TS Folder ---> DVD
By MacPCConsultants in forum Newbie / General discussionsReplies: 6Last Post: 28th Nov 2007, 07:16
