Hi,
I have my capturing system all setup and working fine, I've done some transfers to DVD from VHS successfully so I know that is all ok. What I want to do now is transfer some "original" tapes that are in letterboxed widescreen, and I wasn't sure the best settings to capture/convert with.
I'm capturing in 720x576 PAL format, so do I continue to do this? When I use tmpegenc to convert the video do I use 16:9 setting, or will it have to stay as 4:3? Ideally I want the same effect as watching a DVD widescreen film, with it spreading across the screen - I know I can't get rid of the top/bottom bars, but this is ok.
I'm using iuVCR for cap, tmpegenc for conversion. All advice appreciated.
cheers
Results 1 to 1 of 1
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
VHS to DVD Recording - 4:3 VHS Becomes Widescreen on DVD
By Ocracoke Pelican in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2011, 13:04 -
Question about transferring a MAcrovisioned VHS tape to DVD
By goodsmartman in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Sep 2011, 20:21 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 09:32 -
Legality of commercial vhs tape to DVD for personal use
By wiseant in forum Newbie / General discussionsReplies: 18Last Post: 26th Sep 2010, 18:20
