Hi, I got an AVI file PAL encoded... Is there a tool to convert it to NTSC ? Or to view it on my PC (w/o converting it)? I'm in North America so I can't display PAL encoded movie files... At least not with the tools I have now
Rombolt
To play on your PC it doesn't matter. To make a NTSC x(S)VCD of it I've found that 95% of the time just using TMPGencs NTSC VCD works fine (some frames will be duplicated, this can cause 'sliding/skipping of the picture in certain scences).
Thanks.
You're right, I got to play it on my PC... It was just a matter of getting the right DivX drivers.
And I don't plan on making a VCD out of it.
Thanks again.
Rombolt
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
AVI NTSC conversion to DVD PAL / Windows Media Player
By Jadaag in forum Video ConversionReplies: 2Last Post: 10th Sep 2009, 17:18 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
.AVI conversion from Pal to Ntsc.
By engert100 in forum Video ConversionReplies: 32Last Post: 1st Feb 2008, 16:46
