I would need some advice about the Terratec Cameo Convert FireWire...
I'd need a device to convert old VHS to VCD (or SVCD or DVD) and I lost enough of my time with the Dazzle DVC-80 (I know, it is crap, but, hey it was a present, so at least I had to try).
Reading this forum I almost made my mind on The Canopus ADVC-100, but I couldn't find it in a store close to my place (I live in Italy) and insted I found availability of the Terratec...I saw in the "capture cards" list only one review and, before opening the wallet for 280 Euros, I would like a little more advice from all you experts...
I have a Toshiba Notebook, 2.5 GHz, 512 MB RAM and 40 Gigs HD and i just want to convert old PAL VHS to digital (I know a bit about VCD, SVCD and DVD and got all the necessary software, so my problem is just to get the good hardware...)
thnak you all for reading this
- You deserve Alberto Sordi! -
Ciao,
possiedo la cameo convert della terratec e la uso principalmente per trasferire VHS su file AVI nel PC attraverso la firewire.
E' davvero un ottimo convertitore analogico/digitale infatti non rilevo alcuna differenza con quello che il videoregistratore riproduce.
ho un pc con scheda madre gigabyte sin xp 1394, processore
entium 2.4 GH, 1 GB di RAM, 2 hard disk 80GB IBM e 120GB Maxtor (su cui catturo i file video).
cmq ti consiglio di valutare anche altre schede di acquisizione, magari anche pił economiche, ho visto che la stessa terratec ha messo sul mercato nuovi convetitori.
Fabio -
ciao, Fabio e grazie....
well, I also want to ask about another capture card: the Cameo 400 AV mobile, connected via PCMCIA to a notebook...any news anybody? I've seen that nobody posted experiences with it on the "capture cards" list,
I've read that it captures with MPEG 1/2 encoding, so it is different from DV capturing...
anybody can comment on capturing via PCMCIA vs. FireWire?
Thanks to everybody for your time....- You deserve Alberto Sordi! -
Terratec USB Grabby problem...
By noTitLe in forum Capturing and VCRReplies: 5Last Post: 12th Apr 2010, 17:50 -
auto convert from firewire to DVD with menus?
By neoh74 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 2nd Aug 2009, 18:04 -
Compatibility issue between Cameo Grabster 200 and Vista
By nawp in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2008, 10:12 -
convert VHS into DVD by using Terratec Cinergy XS ?? HELP !!!
By laptopuser in forum Capturing and VCRReplies: 4Last Post: 2nd Nov 2007, 20:17
