has anyone noticed that smartripper runs slower on 2000 pro than me
Results 1 to 9 of 9
i just forced aspi and checked my hard drive,dma is on.I'm still getting 1-2 speed.
DMA is enabled on the HD, but is it enabled on for the DVD-ROM Drive.
you chill the f*ck out, at least give more than an hour between your stupid posts for someone to answer you, and there is not need to type all caps, effectively yelling...
I thought long about even helping you...but here,
Device Manager->IDE Controllers->(pick whichever channel you want or both)->Properties->Advanced Settings
that simple! -
thanks kid,i kept trying to find it under my dvd rom settings.now i'm having a problem with tmpge shutting down after like 25 min of encoding.one more question,should my hard drives be basic or dynamic?
whichever you prefer, but since you dont seem to familiar with W2K, go with basic.
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 19:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 15:26
