svcd logo keeps appearing on film plays back. after i use dvd authoring option in svcd2dvd
send donation and recieved all files .
how can i get rid of this please help
doches77Guest
SVCD logo? what do you mean.. is there a svcd logo in your picture? Even when you play it on your computer? If so then the logo is in your mpg and it will always be there even if you create another format.
If not then your player still thinks it is a svcd. Which isn't completly wierd cause you try to trick your player in playing video which is comform the SVCD standard to simulate it is a DVD so you can put it on a DVD disc and play it in your player.Greatings,
Yf -
Hi Doches!Originally Posted by doches77
Receiving is not enough..
The reg file looks like this: 'reg.xml.zip'.
It is a shrunk or zipped file, so you need to unpack it with a program like WinZip. What comes out of it is a file called 'reg.xml'.
This file you need to copy to the Folder in which the rest of SVCD2DVD was installed. Typically C:\Program Files\SVCD2DVD.
Hope this helps.
Callan -
Guest
Back from my little visit to Scotland......
We have had email on the subject and I know you have it working on one PC. The other PC: There is code in the demo version which adds the 30 secs of "demo version" to each mpg. So it might be that you have run the demo on said mpgs then resused them in the FULL version... Thus if you reuse mpgs from the demo then this could happen. Have you tried new mpgs?
Video playing but not appearing in file
By Vaxkinho in forum Newbie / General discussionsReplies: 10Last Post: 4th May 2011, 11:59 -
Hardsubs not appearing in youtube
By markzz in forum SubtitleReplies: 2Last Post: 12th Feb 2010, 09:21 -
Extra frames appearing
By kippard in forum Authoring (DVD)Replies: 2Last Post: 25th Nov 2008, 19:46 -
Vertical Lines Appearing On Capture
By XBucklawX in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2007, 12:11 -
Following error appearing when i got to burn DVD:
By iainw in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th May 2007, 15:31
