    Nov 2003
    SACRAMENTO, CA USA
    P4 (1.5G)
    Sony DVD-+RW DRU510A
    On a full 4.7G capacity movies
    I was using DVD X COPY platinum to backup it took approx. 30min to rip and 30 min to burn, I like it very much..excellent quality !! but just dislike the Warning logo. Made a temp folder to burn using other softwares eg) CloneDVD, RecordNow Dx.., it took even longer (1hr+) just to burn from a saved file. As you know, DVD X COPY can't burn from a saved file in local HD.
    I know my PC is fast enough and a good DVD burner is not the problem, wonder if there's any softwares that will burn 30-45mins I'll be happy.
    Thanks.
    Nov 2000
    Canada
    30 min. to burn sounds like you are using 2X discs. Switch to 4X or if you can afford it, get one of the new Plextor, HP or LG burners. 8X on 4X +R discs. That show be a bit better...
    Nov 2003
    SACRAMENTO, CA USA
    I can't tell what is the speed on my blank Disc. It doesnt say.
    DVD-R
    Brand: CompUSA
    Size: 4.7G (120min Video)
    Aug 2003
    d/l dvdinfopro from the tools section. it will tell you media speed, media id plus lots moreand it's free
    Nov 2003
    SACRAMENTO, CA USA
    @ tigerman8u,
    Thanks for the tools info.
    @ oldfart13,
    Here's my specs...seems like my media is only 1x speed? No wonder is so cheap $9.99 for 15discs during the pre-Thanksgiving sale @ CompUSA..guess I learned something new.
    Media Information
    Region information N/A not a DVD-VIDEO
    Media code/Manufacturer ID PRINCO
    Format Capacity Not Formatted
    Free Blocks 411107328
    Free Capacity 4.38GB(4.71GB)
    Book Type DVD-R
    Media Type DVD-R
    Media Id Code Speed 1.0x 1385KBps
    Available Write Descriptor CLV 1.0x 1385KBps
    Write Strategy Speed 1.0x 1385KBps
    Data area starting sector 30000h
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
  6. Generally if they don't list the speed on the disk, then they are 1 or 2.4x.
    2.4X usually takes ~24min to burn
    4X usually takes ~14min to burn
