I have a mpeg 2 file capture from TV at 9500 and want to cut the commercial and render down to Variable bit rate of 6000.
When I use either program the result mpeg, whenever there is motion, it is shaky and looks like there is ghosts shawdows. If I used Vegas 3 and everything is fine.
I am not sure if I did some settings wrong. Please help
thanks
Hi sorry about it.
But what is field order? I read that for TV capture I should use Top first and if it is DV then Bottom first. But when I see the setting in Vegas, it says Interlaced, bottom first.
The way I currently encode is Bottom first, but there is no Interlaced options to choose.
So I should encode using top first?
Wilson
TMPGEnc for HD to SD conversion?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 20Last Post: 14th Oct 2011, 17:37 -
TMPGenc TS FPS Conversion
By leftofcool in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2008, 08:39 -
TMPGEnc Xpress, MainConcept, H.264 and QuickTime Compatibility
By PuzZLeR in forum Video ConversionReplies: 6Last Post: 27th Oct 2007, 05:05 -
TMPGEnc Conversion 15hrs remain?!
By Squid_uk in forum Newbie / General discussionsReplies: 35Last Post: 1st Jun 2007, 14:01 -
TMPGenc audio delay after conversion
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 3Last Post: 23rd May 2007, 13:30
