ok this card supports realtime capture to MPEG2 through the hardware and I can capture to that at the highest rez with no lost frames. Is it better to capture to uncompressed YUV2 AVI or capture to MPEG2 dvd quality? Thx
PS please someone respond to my question, my last two post have garnered 20+ views but not one reply. Thx
It all depends what you want to do and what quality you want.Originally Posted by ellandry
If you want to edit the captures, capture to avi 1st. Edit the avi, then convert to mpeg.
If you simply want to capture and burn, and the HW mpeg encoder is good enough for you, use it. -
ok next question. How do I get studio 8 to allow me to use other codecs other than the pinnacle certified ones? It never allows me to check "list all codecs"
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
MP20 Capture Card and Pinnacle Studio 14
By egee17 in forum Capturing and VCRReplies: 0Last Post: 26th Feb 2011, 20:30 -
Setting up capture card for video out to play on TV
By wiseant in forum Capturing and VCRReplies: 2Last Post: 28th Jul 2008, 18:57 -
Assistance with setting up an outdoor photo studio
By wan2no in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2008, 23:33 -
Studio DC10 Plus analog Card, XP and Studio 10 capture split in half
By jackylhome in forum Capturing and VCRReplies: 0Last Post: 22nd May 2007, 23:48
