my vcd is in green and black, the whole thing what is wrong? it is like it got colored in with crayon. when i open the file in virtualdub the movie is fine then when i watch it on any other program it is messed up with green foreground and black swiggly lines through it. can some one please help? doesn't have to do with a codec that is bad? i really want to watch this movie. THANKS.
Results 1 to 12 of 12
If it reads fine in VirtualDub, then load it in VDub, then frame serve it to TMPGEnc for encoding.
This sounds like the classic XviD problem. Usually remedied by installing ffdshow.
/Mats -
ok i tried installing ffdshow and i still have the problem. i think it is xvid codec problem b/c it wont let me uninstall it. i don't understand. it worked fine earlier now i cant even convert the movies with out them coming out green black, pink, red, etc. its like someone colored right over it. can someone please give me any help on this problem. please and thank you. this is kinda an emergency plesae someone help me.
can't anyone help me? there has been 68 people to view this artical and one reply. i just really need some help bad. this is really getting to me it has been 2 days that i can't do any converting. please someone help me. please.
Definately sounds like a codec issue. Have you installed a codec pack, these can cause conflicts and these sorts of problems. My suggestion would be to uninstall all codecs that you have on your system and then just install the ones that you need individually.
Get a life!it has been 2 days that i can't do any converting please someone help me.
You haven't by any chance installed some codec pack, have you?
/Mats -
yea i have installed gordian knot codec pack. and that did nothing for me. because i can't uninstall xvid codec. also i can't unregister xvid.ax that is the main problem with the whole uninstall process. oh and by the way i do have a life. i goto school, work, and do other ciricullar activities. it only take about 10 mins of my time to load in the avi files and then click convert. then turn off the monitor and come back in a couple hours. does any one else have any comments to help me? anything i don't even care if you don't know. just say you don't know. that way i know someone cares. THANK YOU.
No an emergency is when you dont have enough food to eat.. or enough money to heat your House .. dont shout about emergency coz your too stupid to read what other people say, or search thru the forums. Merry xmas.
Sorry about that part - It wasn't meant as criticism (well, at least not harsh). Merry X-Mas!oh and by the way i do have a life.
/Mats -
It has been three weeks now and i still can't get it. i don't know what to do anymore. i don't know what it is that is making this problem happen. i don't know if there is a program that is making this happen. i have tried to uninstall all the codecs and i don't know if i left one out that probably wasn't in add/remove programs. i have no idea. please there has to be someone out there that can help me. the screen is grey, green, pink, all sorts of different colors at different times. please someone out there please tell me an idea. i don't care if it works or not at least someone cares about this problem. i am sure there is someone else out there that has had this problem also. and will have this problem in the future that this forum topic will help. please and thank you.
Sounds like you're in for a complete fresh install of your OS. It's 99.9% certain that it's a codec problem. But again, if VirtualDub can read your file, then use VDub and frame serve to your encoder. But then again, in the long run it seems like a fresh install is needed, so maybe better to take the plunge rightawy?
/Mats -
I finally got it fixed it just uninstalled everything doing with converting and videos. and then just reinstalled everything. Now it works so thanks everyone for your input.
black in picture turns green
By heticu in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2009, 14:51 -
Need to convert VCD (352x288) into DVD and crop black bars off
By smashingly in forum MacReplies: 8Last Post: 10th Aug 2008, 06:12 -
Why green noise or black in YouTube gallery stills?
By brassplyer in forum Video Streaming DownloadingReplies: 8Last Post: 8th May 2008, 00:23 -
Premiere Pro 7.0 or 1.x problem with green or black frames
By bruce & suzie in forum Authoring (DVD)Replies: 0Last Post: 6th Jan 2008, 12:27 -
Adobe Encore DVD black level wrong
By evoshandor in forum Video ConversionReplies: 14Last Post: 15th Oct 2007, 09:17
