on TMPGE the selection for motion search precision. i have been useing the setting Highest Quality (very slow) does this setting help with reducing macroblocks and other noise? or are the other settings better such as Motion Estimate Search (fast). how do these effect the encoding??? THANKS........
the motion search does affect macroblocks, but very lsightly, there isnt that much noticeable difference. Highest quality, and High quality look exactly the same, i dont use highest quality, its a waste of time, and motion estimate is about the same level as low quality.
thats OK, here is the best setting foer motion, ive done a lot of research and testing on this myself, it might be different to some things i have previously said.
use the gop structure
I - 1
P - 10
B - 1
use the quantize matrix MPEG standard (CG/Animation will make your block noise stand out 10 times worse). Use 2pass VBR, and use high quality motion search, the GOP structure is especially important.
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 22:55 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 15:30 -
Mpeg4 Settings for TMPGenc give poor quality for motion.. see pic's
By drewzor in forum Video ConversionReplies: 14Last Post: 13th May 2009, 08:37 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 10:13
